NEK5
3/4 ton status
readymix said:That has to be the most random thread hi-jack I have ever seen![]()
i agree WTF was up with that?
BIGBLAZE433 said:would anyone mind giving me some good instructions????i have no school tomorrow so i`ll have a chance to do it
readymix said:Unbolt the rear end of the driveshaft from the pinion yoke.
Remove the shaft from the sear axle end....now pull the shaft out of the transfer case.
Some ATF might come out so get a drip pan.
Pry the old seal out...be patient...they can be a real PITA sometimes
Install the new seal, be sure to get it in straight. If you bend it....go get a new one.
Put new ATF on the seal area..IMPORTANT...
Now slide the driveshaft back into the transfer case, and bolt it up the the rear axle.
Top off the fluid in the case.
Be sure that you put ATF on the seal area before reinstalling the shaft
Backwoods 72 said:About six months ago I purchased a 72 K5 Blazer. The first thing I did was take the top off of it, well after I washed it I did. It had been sitting in the woods for who knows how long. There had been a lot of people trying to buy it as I later found out, guess I caught the guy on a good day! been researching the soft tops, tigertop, Kana etc. which is best and how hard is it to install?
BIGBLAZE433 said:aright heres another one....how do you get the seal off?
stallion85 said:So did you get it done or what? I hope you feel silly when you are all finished on how easy it was
The best way to learn is just get in there and start messin with stuff, take your time and see how everything comes apart and make sure it goes back in the same way.....
