Gotten the PART DELETE!
Metrodps
Strange but nice guy
Author
earth
I need to find the bracket that hold the power steering pump from coming back at rear. It attaches to the manifold only way I can describe it. The PO removed it when he put headers on and my belt is cock eyed and wearing bad. This is best pic I could come up with. Should be the same on 350 motor also.
I have one. If you still wanted the towhooks from my ad, I could throw this in the box also. $35 total shipped?
edit---Your pic points to the AC bracket? I have the ps bracket, but no ac bracket. Which one did you need?
Now that I've looked at the bracket, I remember that it's one bracket for the ac and ps. I cut the bracket down when I pulled of the ac compressor, so it only goes to the ps. Here's a pic, if it's what you need, it's your's. If you need it for the ac also, that part is long gone.
Here is the reason and area you can see the belt angled.
The piece I have would only go to the p/s. It would not extend all the way up to the back of the ac.
I think your belt is one groove off through. IIRC the ac belt goes to the front of the p/s and the middle of the c/s. The belt that goes to the p/s only runs of the rear groove of the c/s.
This is the bracket you need & you will have to make a spacer for between the bracket & the header flange about 1-1/2" long .Iknow I have some of these brackets but I haven't found them yet I'll look around tomorrow if ya still need one.
I not have headers that is where it went P.O. had headers and tossed bracket. Please let me know if you find one.
L
Ok ,if you don't have headers then you don't need the spacer.
I'm sure I have a couple of these I just have to find them.
I'll let ya know when I locate one
Thanks looked in junk yard but couldn't find one. If you don't find it I will have to try some other yards.
