Greasable Poly kits 52's in the front
Stephen
Moderator
Vendor
Carbondale Colorado
Greasable Poly kits 52\'s in the front
It's not tough to do, you'll use our standard aftermarket main eye kit, #GU37012 for the front and rear eye of the spring. If you can use our HD shackles, we just substitute the standard lower bushing assembly for a GU37012 (adds $4.00 to the shackle kit price) and you're done. Total with plates is $126.00.
If you can't use our shackle plates, you get 2 - #GU37012 kits and the top half of our GU37015 greasable upgrade kit. Total without plates is $81.50
Either way, the top of the shackle will use a 1/2" gr8 bolt and both spring eyes will use 9/16" gr8 bolts.
If you want to weld in a new shackle mount, use our fab-BA175HD bushing assembly spec'd to be 3.5" wide and you're set.
Keep in mind we only use grade 8 or better bolts, our shackle bushings are an exclusive hard compound for longer life in extreme applications and we've even gone to a chromoly steel sleeve for even better durability. This is the good stuff.
