yesterdays project.....rolling on bedliner onto the hardtop
so, i know i said i was going to just spray paint it, but when I got to the checkout counter at my local autoparts store with my paint, we got to talking about what i was doing and the guy at the counter showed me that the duplicolor bed armor kit was on sale for $60. So I had to try it....
I went overboard on the prep work becuase I have done spray in liners before and I know that the entire jobs worth, lies in the prep job. I sanded the top down to remove 99% of the factory paint, then I hit it with 2 coats of self filling primer.
Once that was dry (few days) I scuffed the primer with a scotchbrite pad then removed the dust with an air compressor.
Next, I wiped the whole top with some "prep-all" wax and grease remover. and taped off everything that I didnt want coated. Luckily, i am replaced most of the weather stripping on the top and windows so I just left the old stuff on there and just peeled it off when I was done.
Then, after mixing the duplicolor can VERY well, I rolled a very light coat on just to tack up and give the second coat something to stick to even more.
I let the first coat dry (doing this in the garage with a respirator mask) for 2 hours. Then I remixed the can, and went to town with a heavier coat. The heavy coat took long enough that it had been around 30 minutes since I started, so I actually rolled on another 3rd coat, but kept this coat light, with no pressure on the roller. with this coat I rolled the roller in one direction only over the whole thing to ensure there were no "lines"
note to all, i noticed if you roll in one direction, then roll it back towards you, you actually kinda pull up on the rubber bits you just rolled down, making them stick up more....i avoided this method and i think it helped.
so far, the top has been drying in the garage over night, and is out in the sun right now. i plan to do a day1, day30, day90, etc on this so we can all finally see the real deal on this duplicolor/duraliner/herculiner stuff. Basically, if this doesnt turn out well, then its an inferior product.
Here are some pics, its still drying, but I think it looks great. I am expecting it to fade to a flat black, that is the color i was going to spray paint, so i welcome the fading. right now it is a satin black.
