BUT if I had a good solid floor pan to start with I would of used a sandblaster....I'm to lazy to spray degreaser and wipe it all away.What did you guys use to clean the years of grease and grime build up on the bottom of your rigs? How did you clean them?
would that be to much force of concentrated water in one spot to cause damage?
Would you do it if tht water could get inplaces that could cause problems or is that not even and option of happening?
like what? i pressure wash the whole rig and just avoid the air cleaner.
my truck is spotless
sorry if that sounds a$$hatterish.it can drive through a rainstorm, right?
I would say that a rain storm and a power sprayer spraying up inot the under part of the car on components is a tad differnt wouldnt you say and im still not disagreeing that it will work just putting it all in focus thats all.
