roadnotca
3/4 ton status
I follow, up to optical isolators; do you mean glass?readymix said:On a shielded cable, like co-ax, the eddy currents would develope on the shield and are shunted to ground. Thus not interfering with the signal on the center conductor.
Beyond that you could send signals on a tri-ax twisted pair cable in out of phase pairs. Thus virtually no signal loss. Then add in a few optical isolators and you get near perfect signal transmission........Then you need to deal with the eddys that would remain in the ground plane.
How many people did I loose on that one![]()
Here's a trick to bleed the current from the shield, connect only one end. Thats tricky in application because you have to create a labrinth, without contact, at the open end.
[/convulsing]
