GRRR Ignition Issues
cheyennek20
Wishing I was in Baltimore
Ok, so I get up to go to work this morning and the truck will not start!
Turns over fine...
Getting fuel...
Check spark.....
Fail. No spark.
Check volts to the BAT terminal on the distributor......
12V
Ok, try another HEI cap and coil....Still nothing.
Follow Chiltons monkey steps to check the coil, get .6 ohms for primary coil resistance. Checks good. (supposed to be at less than 1 ohm)
Check secondary resistance.....both of these are supposed to be between 6000 and 30,000 ohms.
1st check- BAT terminal to button that connects to rotor----OPEN
2nd check- GND terminal to button----9420 ohms
Both caps and coils I tried were very similar with both having that open from the BAT terminal to the button.
Is the concensus that I have 2 bad coils?:(
