Guesse what happened after my prom...
You could always just let the the air out of all the tires each night, That way if cought, you couldn't be charged with anything. I did that to someone, very annoying after a couple of days.
Just remember the old saying "Revenge is a dish best served cold." Don't do anything for a while. Take all the legal course of actions first and get your ride fixed. Give him plenty of time to forget about what he did. That way when someone (not you or course, you would never do something like that) totally F's up his ride, you're not the only suspect. I'm sure that a jackass like him makes plenty of enemies, so give him time to forget about you. On a totally different subject, I've been told that you can buy large craft sponges, cut them into letters to spell something really bad, soak them in brake fluid and leave them on his hood. I hear that it works pretty good and he'll be stuck with your message on his car until he gets it painted.
better than letting the air out nightly, remove the vaulve stems nightly, he cant pump them up in the morning with out vaulve stems
I removed valve cores on all 4 tires of this one guy and then pinched the stems shut...hehe, also, drill or punch a hole in the diff cover so the lube leaks out slowly...
The easiest way would be to yank the valve stem out with a plyers. Do that to all 4 tires and he'd have to take them all in to a tire shop. Do that every time you see his POS parked somewhere !!!!!
I'd also get the girl to hang all over you infront of him !!!!!! Set up a vidio camera to catch him in the act of messing with your truck !!!! Then give the tape to the cops.
Here's one, run a drop cord out to the truck. attach one wire to the frame, and the other to a grounding rod. Make sure ground is wet !!!!!(works best when raining) Just wait till he touches your truck !!!! LOL !!!!!!!
Yeah, but if someone is" F"ing with your truck, it stops it. Besides, get the cord put away and no one's the wiser. I don't think meny people would go to the cops and say ( Well, I was trying too....)
Well. If it was me, I'd shy away from wrecking any of his stuff. Then you are both in the same boat, messed with each others crap. You might both end up owing money, or might both get none! HOWEVER, If you would like a little revenge advice, I hear pouring some buck or doe scent into the vents in front of the wind sheild makes for a nice treat when the vent or heat is turned on. You didn't hear this from me /forums/images/icons/smile.gif
Just go over to where he parks and pour a quart of used motor oil under the car every night. he'll be looking all over trying to find the leak.
They will go to the cops (or a lawyer, I guess) if they can win $$ in a case, I've heard of it happening.
I say you got off easy, you could have been in my situation a few years ago and gone with my prom date! I would rather of had four flat tires :-) Anyways sorry to hear about the bad luck. hope it all works out.
Come on guys!!! I cant believe no one has consulteded me yet!!! I am the master of vehicle f'ing up.
Take a pair of side cutters, dikes, or bolt cutters and cut the cvalve stems OFF!!! Unless he has 4 spares he's fuc*ed
Put flour in his gas tank.
Put some old rags in his exhaust.
Drill holes right thru his lenses and thru the light bulbs.
Drill holes thru the lenses then spray the with water.
If the windows are down empty a couple of bags of flour out in the interior.
Get some rubber gloves and spread vaseline or syrup all over his car and cover it in flour.
Put some tacks, nails. or anything sharp in front of his tires pointing up so when he drives off the nails will go in the tires.
EXERCISE EXTREME CAUTION WHILE DOING THIS!!!!
AND IF YOU DONT WANT TO DO IT.... I'LL DO IT FOR YOU /forums/images/icons/smile.gif
Dude, what about, Vasilene on the wiper blades
Super glue in the lock cylinders
Zip ties on the drive shafts
Turn the wheel weights 180 on the rims
Pee on the exhaust header
or one of the best oldies bolgna on the body. Thats some harsh stuff...not. But they would get the picture, huh. I think the collective revengifulness on this site is dangerous. Remind me not to piss anyone from here off...K
