Guesse what happened after my prom...
Find out if he really did it, if he did just asking him to replace the tires. If he will not, I would drop it but add some secure system to your car, then do what you wish. Those cam we all get as pop-ups all the time are a cheap easy way to watch your truck (At home). I had my car in high school broke in to all the time and there is not much you can do. If you really mess up his car he will get p-oed and then he is cut your brake lines, or drain your tranny or diffs ….. Just take cause on retaliations (Sp?).
Try getting some of the stinkiest cheese you can find and get it on his manifolds or exhaust pipe. You think it smells bad when you pee on a camp fire, try this!
I've got a theory on the next idea, but I don't know if it will work. Get a drain pan and crack open his diff cover and let out all the fluid and tighten it back. Make sure there is no oil on the ground or the cover, you don't want to leave any clues. Eventually that should seize up his rear end and possibly send a castrophic failure up his driveline. Preferbly at highway speeds when his torque convertor is locked up so his motor can get in on the fun too! /forums/images/icons/laugh.gif
