I have an H1 wheel that continues to leak air sloooowly. I have taken it apart and the O ring is good, not pinched or anything. Valve stem is tight and no bubbles from the core.
Anyone else run into this mystery? What did you do to fix it?
Not sure if slime is a good idea or not since it is a split rim. To slime or not to slime?
Other good fixes would be awesome. Thanks.
