Hack job Wireing help
katugly
Goddard, Kansas
If any one could look under the dash and see where this blue/green harness goes to that would be grand. 90 blazer, 350,700R4,241
picture.php
picture.php
picture.php
The next item is this harness with a resistor in it. It looks sort of OEM but I dont know since this harness is hacked to pieces under here. Its purple and white and is off of the light that says 4 wheel drive up on the dash. Could any one look for this under there and see what you have.
picture.php
picture.php
picture.php
Ok reverse lights work. Volt/Ohm meter says green is cround and blue is 12volt switched from the key.
Its a diode for the a/c compressor clutch
the other plug looks to me like wiper or washer motor connector
Ok found out where the connector goes, sits at the base of the steering column near the firewall. Still unsure as to what it does though.
P/N switch sounds about right it is a auto. I don't know about if it works in drive or reverse as I have closed the dash up. It doesn't start in either now.
Yeah park neutral or clutch saftey switch i the only thing that bridging the two leads would work with as far as I know.
I did the same thing with my clutch safety cept I just jammed a fuse in it :D
