I get around 15 mpg with a carbed 350 3inch lift 3.73s and 35s. I was getting under 10 and then I added a small cam and ditched the 750 holley for a good q-jet. I think that doubled my power and gas mileage
Go have your speedo calibrated now. There is no way you're getting that mileage with a carb and that gear/tire combo.
Diesel prices move slower than gasoline. When gas jumps up and down diesel remains stable. Unfortunately right now it's at the price it moved to when gasoline went up last spring/summer and now has dropped from. If gas stays these "lower" prices diesel will drop back down.I paid $2.57 this past Sat to fill up mine. Still sucks I wish it would be at least $1.99 again. Diesel is a little over $3 here now....not sure the swap is worth it if its gonna stay .50 more.
Ummmm...cough...uh...ULSD has been out for over a year now...I know its off topic, but is ULSD gonna be more expensive when they switch???
Ummmm...cough...uh...ULSD has been out for over a year now...![]()
The only thing I ever put diesel in is our 38' Penn Bay lobster boat with a C12 Cat here at work. ULSD is coming later on for marine use. Hope it goes okay, we have all sorts of fuel filtering issues with this boat.
reducing sulfur will make it worse.. sulfur is what keeps bacteria fungus and yeast in check..
trust me, there's movement afoot to reduce sulfur in marine and locomotive applications a whole lot sooner than 2012, but since you're having troubles now, we should talk.. post up an email, or buy a membership so's I can PM ya
buy a membership anyway, even if you plan to ignore me..it's the best 25 bucks you'll spend..
I get 36MPG with my K5 running a 502BBC, TH400 (no OD) and 7.56 gears on 38's...
36 MPG in a K5. What the heck is a 502 BBC???Exactly how many is "almost" miles to the gallon?![]()
.What the heck is a 502 BBC???
You gotta be joking.36 MPG in a K5. What the heck is a 502 BBC???
well you get better MPG.he has the same running gear.Michael figured trail time into that.Exactly how many is "almost" miles to the gallon?
I used to get about 18 with my K5 with a 4" on 36" swampers w/ 4.88 geared 3/4 tons, a 700R4 and a TBI 350.![]()
