dmanblazer said:If you look at it real close the hood is a reverse of an original chevy hood
84gmcjimmy said:what year of chevy hood?
Thank
BrianDamage said:cool. Yeah I'd rather have it on hinges, it would be a pain the butt to have to get someone to help you take the hood off everytime you needed to check the oil.
You could use a couple of those lift shocks that you see on the newer truck hoods or hatchbacks. You'd just need to fab a couple brackets and mount them in the approriate place.primerk5 said:Mine is mounted to the hinges but I dont run springs. If I could come up with some of those lighter tension spings They used to make.(not sure if the still do) It would work great.
dremu said:It's fiberglass; why would you need a buddy?
-- A
