Jessie, did you do the headlight relay mod? Where the power is sent directly to the lights and not up through the dash switch?
Yes, I did. That was easy enough, except for the LMC harness is (a) not designed for the 91 stock headlights which use these really tiny pin connectors and (b) were wired backwards for a standard H4 bulb - but that is easily fixed by swapping out the pins. That mod has made a major difference but I am not satisfied with the low beams. Even with the relay the EuroLamps are not any brighter than stock, even with an 80w bulb.
To be fair, I did put in a 80w/100w H4 bulb into the housing. By doing some measuring it appears that the low beam filament is in the exact same location (distance from the reflector) as the H7 bulb that is designed for it. However, as I mentioned, without a proper lens there is no cutoff so the lens just scatters light all over the place like a big blob in front of the truck. I want even, bright light that also has the triangular cut-out shape to light up signs on the side of the road ... E-Code headlamps do that.
For one, i think it would look goofy. For another, Just going to a larger stock style light wont light up the road any better. I vote for add on HID off-road lights. like these.
I am hoping a 1.5cm difference will be hardly obvious. The larger light won't light up thing any better, correct, but having a better design means I can run brighter bulbs and that
willl achieve my goal I've done this in the past with other cars but none had the 150mm headlights, so that's the issue.
I'd love some nice HID lights like that, too, but that's not in the budget ... and those are off-road too. I do most of my driving around town.
Why not get some HID projectors and mount those in your euro light housings? Just pull the fluted lens off and vaccuum mold some clear ones. I'm getting ready to do it on mine.
Unless they have a leveling function my understanding is that they are not legal. Also, I'd be down for that, but I need a housing which is designed for H4 bulbs and/or the HID variant. The Eurolamps don't do that. They would blind folks and I am sure I'd get pulled over (lots of cops around where I live). If I had E-Code headlamps I would consider it if I could find the right kit and it wasn't too costly.
Anyway, it looks like I'll be the first to try this. I'm going to have to source some headlamp buckets from an over/under truck. Does anyone have any they want to sell to me? I'd need all the hardware attached to them, like the adjusting screws and springs, headlamp holding frames, screws, etc.
