has anyone seen a lifted quad steer ????
boggerless
1 ton status
dearborn heights, Michigan
i was looking at one in the gas station this morning. could those cylinders move bigger tires?? i think it's a POS.even the fake stepside look.LOL soooooo anyway has anyone? :grin:
I think quadra steer is awsome, it gives you a Dana 60 rear end in a half ton :laugh: And as far as off road i have seen em crab walk ot of ruts after getting stuck. I realy like the idea, too bad Gm is dropping it :(
they are dropping it? first i've heard of that. tho it doesnt suprise me. its a cool idea but doesnt seem like there are too many on the road. the bed looks a little goofy too.
IIRC, GM basically forced buyers who wanted the Quadrasteer into buying a fully-loaded (optioned) truck. The options package with Q-steer in it was like $5k; again, IIRC. I recall reading a review in Trailer Boats magazine of an '03 or '04 K1500HD with Q-steer; the truck's MSRP was nearly $45k. FOR A HALF-TON TRUCK!!
Just goes to show ya... GM engineers can come up with some cool stuff, but the dumbass MBA's can't market them to save their lives.
Its a really good idea its just that for the same price you can have a 2500 HD with the Duramax/Allison...
Oh and its not meant to be a fake stepside "look"....
yeah GM loves to do that nowadays. Come out with something great, but you can't get it unless you buy the SLEXPCSTV package.
first most of you guys are wrong they dropped the price to 1.5k and that rear axle is a d60 w/ 35 spline inners and outers beef, the fake step side is mandatory from the government b/c you cant have the tires sicking out the side the fenders like they would if they didnt and last tow w/ one and youll never want anything else
someone explain why 4 wheel steering is not sweet. :cool1:
charging a truck load of money for it isn't cool. :mad:
as far as the bed goes, most of your guys have no problem cutting up cherry k5 for truggys, so why would you have a prob cutting up a pick up bed? they have to do it cause the gov makes them. they don't have a choice. you do. so run right out and buy one and swap on a regular box or cut it up, or don't do anything. :blush:
There's no reason why you couldn't lift a truck with Q-steer. I don't know how big of tires it could turn, but I'm sure bigger than stock. There is a limit to how high you could go without lengthening the harnesses. The control module is frame mounted.
Also, the "fake dually" look is because the rear track width has been widened to accomodate the rear steering and the government requires the tires to be covered. The frame rails are so far apart on the newer trucks that putting the tires in any closer would make them hit the springs. Take a look at a normal (no Q-steer) and you will see that the springs are just inside the tires. If the same system was applied to a different platform, the track width might not have to be so wide.
I have a little design time into Q-steer.
Can't you get away with 4" of tire sticking out from the body? I heard this from one of my friends along time ago and never checked it out.
No, state laws usually cover these things and I know in MN the tires have to be completely covered. I'm sure there are quite a few states like this and even if there aren't, I'm guessing there's a Federal DOT law about production vehicles.
Here ya go. I think its bad ass.
"Now, this might seem like it would interfere with the operation of the rear wheel steering, right? Actually the only modifications that were necessary were to extend a single hose and a wiring harness;"
Drool....
I think in Cali its under 4 inches... even when it sticks out 6 you'll probably only hear its illegal once a year from a cop... at least in this town.
and i'm going to raise the BS flag on this one. the steering racks used only give a very small amount of steering travel on the rear axle. no way it would turn it enough to let it walk out of a rut.
GM, had bought a set amount of quad steer axles, and like someone said it was only on the "pricy" trucks, and then they decided to lower the cost of the mod, and then allowed it as an option, but still they could not re-coup their money so once the stock is gone so will be the quad steer........
chief :k5: :usaflag:
I agree, but not only that, the tires turn opposite eachother under low speeds, only at higher speeds (something like over 55mph) the tires turn the same direction.
