One of our most popular items are GM / Dodge Dana 60 hubs. Finding a "cheap" Dana 60 can be tough but if you find a DRW version, the conversion is as simple as grabbing a set of these. We offer many options on our site.
Use code "CK5deal" to get an additional discount!
www.hillbillywizard.com
Bonus, if you select an option that includes studs, you'll get the HBW-563 wheel studs. These are 1/2" longer than OEM studs which are perfect if you're running a spacer plate or aluminum wheels.
GM Dana 60 SRW Hub
Hillbilly Wizard sells the hard-to-find parts you need to build your project vehicle!
