hd 10b tierod on d60?
muddybuddy
1 ton status
Northern, VA
i have a heaby duty tie-rod for my 10b, will it be able to work on a d60, maybe with different ends?
Its a little longer but not much, maybe 1-2". Really depends of how tight your 10b tie rod was built. If the ends are screwed all the way in, you will have to cut some off. If they are adjusted out a good ways you will be fine.
