Blazin'4x4
First little bump on a rock and its bent! thought $200.00 would have proven itsself.
. I have hit mine on a rock and not bent it. I killed my diff cover, but the tierod held up. You bent it because you parked you truck on it. If you going to be stupid you will damage ****.... don't bitch about how a product will not hold up if your the one that is not usong it for what it is meant for.....
I hate stupid people...
?4X4HIGH said:If safety is your first concern then why doesn't your e-brake work?![]()
RONALDHANCOCKJR said:Not sayin its a bad product, just missrepresented in the ORD advertisement. I had some pretty high expectations from the tie rod after talking with the salesman @ ORD. Lets also keep in mind that it is a small bend, but a bend none the less.
!!CDA 455 said:I know what you mean.
One time I used a four-sided cheese grater as a drink-holder. The damn drink kept leaking out of all the holes![]()
camok5 said:I dont see how this is in anyway ORD's fault. The same thing would have happened had you bought the same size tie rod from any company.
