Head gasket
Yes yes and yep going to fire and run up to 1800t o 2000 for 20 min
Used royal purple assembly lube and primed with. Oil witch made a bloody. Mess.
Valve adjustment work out good ?
I use the method that was shown in the video and usually don't ever have to pull a cover back off.
once in a while you can get a clicker, but usually it is spot on...
I don't understand why people fight all that hot oil splashing everywhere, smokey headers or manifolds... The factory could never set them running on every engine they produced, so I'm sure they came up with a set it and forget it method a long long time ago...
glad it all worked out for you!! :waytogo:
Ya it did great no lifter tick, no funny noises sounded really good.
Surprised it worked really well
I WILL TOMORROW!!!!!want to check timing then go wash the darn thing its hard to see out the windows
