Ok so finally got my head gaskets done and the k5 up and running, good compression, no leaks or smoke nice idle only one problem.. Doesn't seem to have any power when going down the road, even at wot acts like it's dragging, checked out timing and seems to be right, no back fires or any thing like that just the lack of power. Only thing I'm not too sure about are the lifters being adjusted right. But they don't chatter and all seem to be operating right. So any help on the situation would be greatly appreciated! Vehicle is a 88 k5, tbi 350 and the 700r4
. Leaking from somewhere down the back of the engine, so knowing my luck I can probably say the intake manifold gasket didn't seal right on the rear Or.. Not sure if possible but maybe the head is leaking oil? All I know is that this thing has been nothing but problems, one after another and I'm almost too the point of throwing in the Towle
but come to think of it, I probably didn't let the rtv sit a little bit before I threw the intake on and torqued it down, which I heard that could cause the rtv to spread out and not make a good seal? and the idle Is really smooth and acceleration is pretty good too for a max speed of 85..
also if it happened to be something with the head, it would probably smoke like crazy?
