Headlight questions
k5floyd
Friendswood, Tx
So first I have an 88 k5 with the quad headlights 2 on top 2 on bottom. Currently only 1 of the top headlights work. I plan on doing the relay mod but also Im looking to replace all 4 sealed beam with the replacable bulb housings. My first question is which headlights are which or how do they work? I think the top ones are high and low beam and the bottom ones are high beam only? Next question is what size are they? I was looking at the Hellas but I cant figure out which ones I need.
I went and looked at those and they are super nice. Do they make a hi/low combo light? All I saw was the low beam or high beam. Then again I guess I could swap to a 4 headlight grille and buckets if I had to.
the 4x6 come as low OR high only .
they also are wired so that when high is on the low stay on for best light output.
the 5x7 bigger for 2 headlight system are a combo high/low unit .
