Heads???
Confedneck
3/4 ton status
Lehigh Acres, Florida
Ok guys, bought an 010 4 bolt 350 today, its already .03 over with one sleeved cylinder.... are vortec heads compatible with this motor, i believe it was used 69-75...do i need more info off the block stamping or??
YA! /forums/images/graemlins/thumb.gif
Vortecs and a supercharger! /forums/images/graemlins/thumb.gif
To make that much power you're going to need a cam with way more lift than the Vortec heads can handle without modifications. /forums/images/graemlins/frown.gif They probably won't even flow well enough to support that power range, regardless of cam lift. To make that kind of power you're going to have to step up to the plate and buy some good aftermarket heads. /forums/images/graemlins/eek.gif 450-500 HP is asking a lot from a 350.
Wow...I agree, Vortec's arent going to cut it. AFR's, Brodix or Trick Flows. If your serious about this buildup I would suggest you also post this question on the Team Chevelle board under the "Performance" area.
http://www.chevelles.com/cgi-bin/forum/ultimatebb.cgi
Theres several people there with these kind of motors who are more than willing to provide info /forums/images/graemlins/thumb.gif.
I use to be on that board all the time a few yers ago when I had my chevelle. Great bunch of guys or at least use to be
