My point is when you get your axle(s) stuck between a rock & a hard place what's going to give first? If not properly engineered at best things will "only" bend. If they break you'll be without steering.
Like I said I don't know how to set-up full hydro. I've just read in building your own it's a common mistake to build a system that exceeds the failure limit of other steering components.
So are you saying that ram is too heavy duty??? Should he use one that will break before the rest of the steering components??? If something is gonna break, its gonna break.
Looks good man, keep up the good work.
Otherwise, looks sweet!
If you ever have the urge to run over some cars, there are alot of rednecks here with donor cars waiting in there yard..
