hedders and oil dipstick
George_Pimpdaddy
Edmonton Alberta Canada
so on my 89 blazer i installed a set of hedman hedders and now my factory oil stick wont line up good to the hole in the block so what have some of you guys done to solve this? thanks
same problem here
looking at the bracket it looks like you can trim a bunch of the bottom, and it will line up, i just havent gotten that far yet
there's a cheaper solution. grab the tube, and bend it so that it clears. my Edelbrocks used a "P" shaped clamp to hold the dipstick tube to the header tube.
My Afterburner headers caused the same problem. I just "modified" the bracket a little and bent it and cut a little off the bottom. Worked for me, but I dont know what shape your headers are.
-Harrison
i think i got it solved i called the local partsource and they ordered me in a flexable dipstick for my motor gonna cost like $35 but it will be in tomorrow only thing is its only like 7" long outta the block so its a shorter stick but should be better than i have it now
i cut some of my bracket off, still wouldn't work, the header flange was to thick
so i took one of the bolts out of my center bolt valve covers and bet the bracket to fit
works perfect
On my big block, I lost the factory dipstick, put in a lokar, and since I have a bodylift, I bolted it to the top of the frame rail, poking out into the fenderwell. Easy to check the oil without popping the hood, and aint had any problems out of it.
