Never seen this before so thought I'd post it up for anyone having a misfire. Recently my 78 K5 failed emissions due to high HC. It had fairly new plugs, wires and cap/rotor in it. I could feel the misfire at idle and in drive. Threw another set of plugs, new cap and rotor on. Misfire still there and even worse now. You can see how bad my HC (unburned fuel) was here:
Found what was causing it. The 4 screws holding the coil inside were too long and breaking through the cap causing the rotor to sometimes spark up one of the screws causing the misfire. I felt kind of stupid for not catching that when I replaced the cap but I have never seen this before.
Confirmed its now cleaner on the HC side and should pass now.
