Hey all, I need help with my HEI conversion.
Fairly new here and have some issues and want to give back as I've been a lurker here for over a year. Incidently I should have probably titled this as "need help" not help in the subject oh well can't change it now
I need help with my HEI conversion and I'm taking a bunch of pictures so this will hopefully help someone in the future. Most of the readme I've found so far don't have pictures
So this last year I bought a 74' and am in the process of getting it running better/restoring. It's got a 350/th350 and a edelbrock 1902 (quadrajet) that looks pretty new.
Engine and Tranny are less than 20k rebuilt. It's been randomly studdering/loss of power at completely random times. If I throw it in neutral it sometimes makes it better.
I think unrelated but gas guage is jumping around - I'm guessing bad ground. I also have a leaking gas hose that goes to the gas tank (drips a little when filling up. It's 28 degrees out in Portland right now and don't want to drop it right now. I have almost run it dry, so that next fill up I'll know what size tank is in my 74, so I will probably do all at once - gas tank drop, gas tank hoses replace, in tank fuel sensor replacement (need to know the size of my tank first), check the tank ground/replace.
Things I have done so far for the studdering:
I figured at this point I should just convert it to HEI. I've read a ton on the conversions and think I had it down, until I looked at my truck.
From what I have read
This is from posts and here http://www.oldengine.org/unfaq/hei.htm
What I think I have figured out so far
In summary to convert it I think I need to:
Pictures are following
Coil setup showing the wires
Mystery brown wire
Harness
Wiring schematic - I'm thinking that maybe the 20 P/B is the resistor wire that is actually the red from the coil that goes into the harness and hookes into 3
Magical 20 P/B -3 same as above
I think the resistor wire is in the top block not the bottom, but it doesn't specify anywhere
I'd also not like to thank the idiot that put the dizzy on the rear of the engine on chevys - I'm worried my HEI from summit that I got won't fit until I get the ORD 1" body lift I got in.
- replace full pump - almost **** myself it was only 19 bucks
- replaced fuel filter on quadrajet
- replaced gas cap
- put heet in
- replaced PVC
- replaced in air cleaner PVC filter or whatever the hell it is
- replaced air cleaner filter
- replace dist with an HEI dist
- replace 12v hot wire from dist to fuse block as it has a resistor in
- remove the starter hot wire that gives full 12v on startup as it is redundant when you have full 12v to fuse block on IGN
- .45 gap for HEI, AC delco
- Start tuning at 8* degrees
- baby poop brown off the back of the coil is the starter full 12v hot - can possibly just cut/cap it off for the moment until I can take whole thing off
- stripper red off the coil is the positive that maybe has the resistor in it but I'm confused that it goes into a harness. From what I've read the resistor wire going into the firewall block is a white wire with a somewhat material wrap around that, I don't have that (3 spot on diagrams below)
- Orange is the ground wire? Who uses orange as the ground wire?
- I should have looked at the top of the coil for + and - but beers were calling and I forgot
- Remove both wires from coil, coil, and harness
- wrap tape around harness because I'm lazy, leave the ground from harness because I don't want to deal with it right now
- cut brown wire and cap it/wrap it with electrical tape
- Since I can't figure out firewall pass through just ignore it
- Wire 10/12 guage red wire from new HEI dizzy bat through firewall and into a spare IGN slot I have
- Time it and done
Mystery brown wire
Harness
