Is there an advantage to adding one of these? Or not really.
https://www.summitracing.com/parts/dui-240001bk
Yours shouldn't have amd HEI ignition in it. If it does, the factory ICM style ignition has been removed.Yes, does that make a difference?
I have a nagging miss at idle. It's hard to tell if it has a miss revved up, when I pulled the old plugs they all looked as though they had been firing. And it passes smog.
I was wondering if this would help.
Try pulling the IAC solenoid and cleaning the tip on the solenoid and the port on the injector
Gimme call on that if you have questionsAh, well, I'm certain this thing is completely bone stock.
I'll check out the injector! Thanks!
I always have my phone on me, I'm up when the sun is so no worriesI will, no doubt. I know nothing about injectors.
It will do you well on Gold Bar Rim.
Just remember no clutch dumps, theres plenty of traction
Learn the "bump" and the rest will sort itself outYeah, I'm glad I have newby run to get used to things.
Thanks, good info. I didn't realize the ignition was different with TBI motors, I have a lot of learning to do. My previous 3 squares were all carbed.
