BC - TEXAS
Registered Member
I have a '70 K5 and access to an '87 Blazer. I want to convert to front discs and the parts are all good...can I use the OD Trans/Transfer case in my '70?
Parts vehicle. No passenger door, no front clip. Owner says, "engine ran when I bought it, both axles are solid and trans/transfer case are all good.is the 87 in good shape?
Yes, the transmission and t-case will bolt up. If you have the driveshafts, they’ll likely bolt right up with the conversion.
You’ll need the 700r4 lockup control. I went with the B&M lockup with the vacuum TCC solenoid cut off. I l had a hard time getting the transmission to unlock following the instructions but I have it all dialed in and it’s great doing the opposite of what the vacuum switch instructions were.
If you go the B&M route, you’ll need a speed sensor off from the transfer case for it. It calls for one of two specific pulses. I have two different ones. One has the cable pass through (for my speedometer) and the other pulse out for the B&M transmission lockup controller.
I had move the crossmember back about 3/4 of an inch. You’ll likely use the crossmember from the donor truck. Drilling the frame for the mounting holes was easy.
Use all all new poly or rubber mounts. Whatever the engine mount is to prevent too little or too much movement.
I did the swap from a TH350 to 700R4, but kept the same transfer case. I did have to move the crossmember back and I had to get new drivelines. Using the donor truck drivelines will save some money.Your information is from putting a 700r4 into a 1st gen originally equipped with a TH350? Because a 700r4 is either 2 1/2 or 3 1/2 inches longer than the TH350, if memory serves.
Guys - Thanks so much! If I'm reading this right, I should be able to do some fairly minor modifications and upgrade my ride. With 35" Nittos, the drum brakes just don't cut it. I also need to 're gear', I guess as it turns a bunch of RPM to hit 60 MPH. I think 410's should make it better, especially with the OD tranny. It'll always be something, but you folks have given me some great info. Anything else you can think of?!!
LOL...I'm thinking I can have the diffs re-geared and have no idea what that should cost. You guys have already been great and have confirmed I can save some money this way. It's always something!!
Thanks!!A front and rear regear will run you approx $1000 with the gears. Less if you can do it yourself. That’s why a lot of folks will try to find an axle that’s already got the gear ratio they want.
