Hey folks,
Have a leaky transmission for years, had some extra cash and some good references from friends at the local AAmco. Well, i turned it in and they said i had various leaks....while repairing, they said, the torque converter was old/worn, I said go heavy duty. They said my transmission looks good elsewhere, while apart, I asked for other possible upgrades, shift kit, clutch disks, etc. Anyway i said lets do it...a rebuild with a lifetime warranty. $2500. Well I picked it up and vehicle looked out of sorts (somewhat) e.g. service engine light was on (had to have guy troubleshoot - vacuum hose was off), firewall plastic behind engine was broken, lost keys, exhaust was a little cockeyed, etc. Anyway, pick up was not smooth. I left after about an hour, it shifted ok, not much different from prior to work...got home and trans is still leaking towards rear near transfer case. Somewhat pissed (fri. night - can't call till Monday) I looked at the paperwork and they put in a whole new transmission!!!!!!!!! a re-conditioned one!!!! Well I didnt want someone elses mess, I wanted my mess fixed, if you know what i mean. Also the paperwork said only a heavy duty converter, nothing else but jibberish, not kevla bands, shifter kits, etc . Of course I should have read at the shop but it was late and a confusing time. Also, when I was receiving paperwork the desk lady said the computer does weird things and lists the work on receipt in an odd way, making the receipt sort of a mess. She highlighted the lifetime warranty part....my pessimesstic mind believes that was to take my eye from the part that said AAmco reconditioned trans. to get me to sign and leave...maybe not. I get home, it leaks, and the dipstick is not even bolten to the rear of engine (I asked them to make sure of this)
Long story - but looking for advice???? I am calling first thing Monday and expressing my concern with the shabby work and I will get a more detailed receipt. I will get them to fix leak/dipstick! Do you think, they wouldn't install certain HD parts as we discussed? What else should I be concerned with? Should I ask for my transmission back or are there rebuilds ok? Is replacing my trans common?
I'm pissed! thanks in advance for any help!
