Help Can't Remove Tranny Bolt!!!!
Just a little note,If you have trouble with swivel sockets that will not stop flopping around try to tighten and if that don't work I put some black tape around it a few times works great!!
Mike
The last five engine swaps,I did the same thing.with a wrench from the top.The top drivers side is the hardest to get at.But i can get all the bolts from the top except the bottom-most bolt by the clutch linkage.of course,I've got scrawny arms and small hands and am working alone 98% of the time so I've learned to adapt.Good luck
