Houston_t
Registered Member
So a couple weeks ago my truck began running like crap while at a stop light, it was bucking ( kinda like when you try to cut a carbed car off but i wants to keep running ) I got it over a lane then it cut off started it back up and same thing, then it wouldnt start anymore.
After doing some searching here i did a spark test and had no spark so i took the module to get tested and that did the trick. Went on vacation for a week or so got home and let it warm up for 10-15 minutes then went to run errands.
Come out of the store start it up go straight into reverse and it dies after about 5 feet,( now im blocking traffic in Meijer parking lot ) crank it over a few different times and nothing, its sat key forward while i struggled to push it back into the parking spot ( yea no help offered ) get in crank it over and it started but died after maybe 5 seconds ( did this about 4-5 times )
I finally got it started and running for more than 5 seconds so i back out of the parking space and take off but only made it maybe a couple hundred feet before it died again. Started right back up made it another couple hundred feet and then it dies soon as i tune onto the main road. I pull to the side and let it sit for about 5 minutes while i started to type up a for sale ad, tried the key again it started ran perfect the 2 miles back home. i let it sit for a day or so took it out again started right up and ran perfect drove it maybe 5 miles to the store, shopped for about a half hour came out and same problem again.
Where should i start my trouble shooting with this ? Truck is my daily driver so i need her running at her best, money is tight from vacation so i dont wanna just start throwing parts at it.
