I agree with ntaj*ep that parasitic or key off battery drain test would be one of the first things i would have done. Did you already do that?
I have had to do this test to find out where a short is... because i'd leave my truck for a day or two and the battery would be dead.
But I thought this was about the windsheild wipers so I was adressing that other problem.
However, this test will help you isolate the short to ground.
If you find you do have any key off bat drain, then you can start pulling fuses to narrow it down to which circuit it is on, when you pull a fuse and that reading drops to zero you know you have found the right fuse. Then you'd have to figure out how many and which circuts are off that fuse, theres usually several circuits.
Hey ntaj*ep I've done it with a voltmeter instead of an ammeter... hooked up in series between the neg bat post and neg bat cable. If its a few tenths of a volt you're good a half a volt or more and something ain't right.
Could you do it this way as well?
