finally got some pics for you of what mine looks like with 6* shims. The first pics are of what it looked like when I had the 6* aluminum shims in there after I put in my zero rates
and the later ones are of what it looks like now with the 6* steel shims with the offset center alignment holes. Make sure if you're running a zero rate with your shims like i'm doing, to run a grade 8 3/8 bolt as your alignment bolt thru the spring pack or you might have bolts that look like the last pic
. And some people think there's no stress on them
