SUPER'BURB
So I pull my old leaking fuel pump to swap in the new one.
Everything comes apart fine but while installing the new one I see the rod that pushes on the pump is in the way.
I try moving it manualy, no movement.
I try turnig the crank by hand, no movement.
I try cranking the motor over several times with the starter, no go.
What am I not doing? I have changed many fuel pumps and never had this problem.
Thanks in advance.
Thanks in advance.
