** HELP !! ** -- Hydro clutch pedal support bracket???
PARTSGUY
Registered Member
Jacksonville, FL
I am in the final staged of the SM465 swap. I got the support rods mixed up for my clutch pedal setup. Anybody have any good under dash pics of the two rods that support the clutch pedal? How about a template or any recommendations on drilling the firewall for the clutch master?
Curtis
PS The setup is from a 86 and Im working on my 90.
Your firewall is already dimpled for the clutch master. i'll go snap a few pic's of the pedal stuff from my crew cab.
Rene
OK first pic is engine side as straight on as I could get. Should give you a better clue where to look for the factory dimpling.
These two show the clutch stuff from the other side. The braces go to the clutch master holes and right through the master itself.
From the top (gauge cluster removed for clarity...lol)
This pic from the bottom side.
Rene
SWEET! Thanks man! I think this thing may finally be drivable again. I just have to drill the holes and finish putting it together in the morning. :D:bow::waytogo::thumb:
The reservoir mounts off one corner of the wiper motor with a bracket.
Rene
thanks Rene. I almost feel like this should be a stickey bc its talked about once a week really. plus I have really found these to be the clearest pictures of the mounting locations.
