I am getting a real loud ,(like people on the streets looking back) nasty noise out of my truck when I get off the gas to slowdown . It is a really loud growl/rubbing noise beyond gear whine noise . If I just barely touch the gas it pretty much goes away .
Truck is an 80 with a 350 , sm465 and np 205 . Front hubs unlocked , transfer case in 2wd , so I'm ruling out anything in front of the transfer case output shaft . It started fairly low key , like a tire whine . Front tires were done , badly scalloped , so 4 ball joints went in , left and right tie rod , alignment and 2 new tires . Front driveshaft has 3 new U joints and the rear 's are new also . It's gotten to the point where I'm afraid to drive it . I can feel it trough the bottom of the truck on the floor and through the steering wheel .
I have noticed that it is there all the time , even when at cruise speed , but gets really loud on deceleration and really bad decelerating in 1st and 2nd gear , alot less so from 3rd gear .
Transfer case is full of 80/90 and tranny is 1/2 full . Tailstock seal leaks into transfer case until tranny settles to 1/2 full . I got the truck like this 2 1/2 years ago and been meaning to fix it since I bought it . I filled the tranny to see if it made a difference and it makes none . I know , I should have fixed this earlier , but I am not 100% sure that the noise is coming from the tranny . When decelerating and I get the growl , I can push in the clutch and the growl does not go away . If it was tranny , the noise should go away ?!?!
Need suggestions here guys , thanks .
