My old 81 Jimmy came stock with 2.76's. They're not that common, but they were out there. Lucky you...
For me, on 33's with those gears the only time I really used 4th gear was freeway. Worse yet, I towed with those gears and tires.
Sounds like your diff needs a rebuild.
play in the straps sounds like a wrong U-joint was installed. There are several variations depending on year and stuff. The common ones are the 1310's, and S44 joints. Then if the diff has been swapped from another vintage you get the fun of conversion joints.
A 'wrong' joint could definitely have finished off the pinion bearings...
as for the solution it depends on what you want to do. If you're staying stockish and on 31's and can find a good set of 1/2 ton diff's with say 3.42's or 3.73's...it's a pretty easy swap and will make the truck a lot more responsive. If you plan on 'building' the truck anyways it'd probably be better to find a set of 3/4 ton diff's right away and start dealing with the rest of the stuff needed to run those (3/4 ton is all 8 lug stuff)
Rene
Grabbed the pinion yoke , gave it a shake and it has lots of play and my U joint caps have play in the pinion straps
Rene
Also no difference driving in 2x or 4x so TC didn't seem to be the culprit either.
