I need HELP Identifying Electrical Connections in my 90 k5 blazer. The previous owner had an aftermarket alarm kit installed and there was a bunch of really bad splices into the stock wiring harness instead of just making connections at already existing nodes. I have already cleaned a bunch of it up but need help identifying and sourcing a few things.
First thing is the connectors for the top ports. I found them here at the link below but they are approx. $30 shipped to my house which i think is insane.
http://www.americanautowire.com/shop/connector-terminal-kit-ato-fuse-box
If anyone has a better source or even more information about them that would be great. Like what those ports are called? What the connectors are called specifically?
Second is where would i find the clip that the purple wires connect to in picture #1? It is the part of the fuse panel that makes up the connections that run through the fire wall. Picture #2 is a view from the engine compartment side.
Third is i need to replace the contact circled in yellow where the orange wires are connected. Anyone have any idea how to go about this. I guess ultimately i am really just trying to replace the wire running to the contact but not sure the easiest way.
Last of all do you have any recommendation for an easy point with in the engine bay to connect to that only have power when the engine is running.
Thanks Guys for the help i have tried searching for hours and its only made me dissy.
but i have another auto part store that i frequent and they have a huge selection. I picked up matching orange pink and purple wires as those will be the runs i am replacing due to poor splices. Luckily all three only run to the steering column so it should be easy once i get the connectors. The connector in the first 2 photos as well as the connectors at the column i do belive is the said "uninsulated open barrel F terminals" and are indeed held in place by a little tang. I will be removing one and sizing later for that which takes care of the purple wire.
