SWOO
Registered Member
I removed the front clip and found my radiator core was not bolted to the frame. When I saw that I just took everything off. Diff, fenders, leaf springs, shocks and radiator. I removed it down to the frame. I didn't remove my motor because of time. I'd like to clean my frame and repair what I can.
Questions:
1) How do I raise the body to replace Body Mount Bushings?
2) What instrument do I use to clean the frame?
3) After cleaning what is the process of painting it. Which Chemicals do I use to clean, prime and paint the frame?
4) How do I clean and what do I use to replace the underside insulation of the body?
Questions:
