So i have been driving my truck for the past few months and it has 160-170,000 on it. Just the other day i got on the freeway and i noticed it didn't want to shift into the last gear. Before i could get home it went out all together while trying to go up a slight hill. Now it won't shift out of first. I have park and reverse as well. So i all i could do becuase it was dark was check my fluid.
After doing some research this is that approach am thinking am going to take but i can't address it till next week so i thought i would see if you guys have any advice or input.
1. I was a less than a quart low so i will start by adding fluid. (i dobt this is it)
2. drop the pan (and check the fluid/debris)
3. Check the Governor gear
4. Check the valve bodies
5. then TV cable
That is where im lost any input would be helpful along with details on things to look for. Im hopping to by time before i have to replace it.
5. then TV cable
