A CK5 survey never kept a suspension link from bending in the past....
What does the Campbell rig weigh? What does YOUR rig weigh? The FS Values in ExcelCAD are calculated based on the vehicle weight. The heavier the rig, the lower the "margin" will be for a given tubing size. In other words, it's dopey to copy a Shannon Campbell suspension on a vehicle that weighs 2X more...
If you want to be smart, put his values into ExcelCAD and see what the FS values are for his design.....then make sure that your design has numbers that are at least as good.
