The front crossmember on my gooseneck trailer has been bent for awhile, and had some VERY questionable repairs done to it. I've been ignoring it for a couple of years, but last week I forgot to put the jack up all of the way and it broke the suspect welds, so it's time to fix it right.
I cut out the bent C channel front crossmember already, but before I weld in a new one, I'd like to fix the bent stuff that is left.
Hopefully you can see well enough in the pic. The bottom L channel is bent pretty bad (I may cut that out and replace it too), along with the upper piece along the edge of the deck. It may be hard to tell in this pic, but the upper channel is bend back on the lower side. I need to try and pull that back to vertical.
Also:
As you can see, the drivers side upright is bent in quite a bit on the bottom. This is what I'd most like to fix.
I'm not sure how to go about bending it back out though. Any thoughts on how I can accomplish this?
@ktmoutfront you've done a lot of trailer repair, and frame straightening tricks?
Also:
