Alright, it's not 100% but you bastiges have gotten into my head again and I'm on a quest for torque. I was planning on getting a 383 stroker to bolt my TPI/EZ-EFI onto and stuff into my blazer. Now I'm probably going to sell the TPI setup and the Fast kit, the fresh heads I had and the running 355 that's in the truck now with the hopes that I can take a chunk out of a BBC with EFI. There are a couple gen VI 454's on craigslist locally that I'm going to try to look at in the next week or so. One of which is at a local machine shop in pieces already. Waiting to hear back from the guy about if it's ready to be put together or needs machine work. He's asking $600.
So, assuming that I go with a setup like that I'd like recommendations on heads/cam setups. I don't care at all about HP, but want some nasty torque (shooting for 550+) and if I can get a slightly lopey idle I wouldn't be upset about it
I'd probably end up going with the edelbrock MPFI sequential kit or the FAST kit that comes with the 4bbl throttle body. I don't have a fortune to spend, but don't want crappy parts either. I'd like to do this once and be done with it so everything needs done at this time.
I don't want an LS, plus there aren't really any around here anyways.
Also, aside from fuel pump/lines and a new flywheel, what else do I need? Can I reuse the HD clutch I have now or does it need replaced for the BB application? I know I need headers, but that would have happened with a small block too. If I go with the FAST kit, I know I need a distributor. Do I NEED a spark controller like a 6A or something comparable? I will RARELY run whatever I go with up near the red line. The 465 isn't built for quick shifts and speed anyways...
Looking forward to hearing what you seasoned BBC guys have to say. I know exactly jack about big blocks. Let's hear it
I'd probably end up going with the edelbrock MPFI sequential kit or the FAST kit that comes with the 4bbl throttle body. I don't have a fortune to spend, but don't want crappy parts either. I'd like to do this once and be done with it so everything needs done at this time. I don't want an LS, plus there aren't really any around here anyways.
