Barbed pushloc fittings.
You would think. Speedway shows them
Do they need clamps or are they good with just the barbs on there? Almost seems too easy...
Apparently you've never put a pushlock hose together![]()
Let me put it this way, make DARN sure the hose is run through all the holes and loops you want before you push the connector on........
Ok, so I'll definitely be using the push lock stuff from the pump to the carb, and maybe from the tank. Do I need a return fuel line? I'm not currently running one.iirc, push-lok is a 250 psi max... and yeah, it can never be pulled off, you'll need to cut/shorten to remove... iirc, it's a Parker innovation... heavy in the marine biz...
did you find out the flywheel info? haven't had a chance to refresh my memory on that stuff yet... most of the times, it's not a difference I'm dealing with in the boats...
I'd say your right about the flywheel, the return fuel line only needs to happen if the pump has a return port on it. The pushloc should be fine for your entire fuel system!
You don't need a return
