87GreyGhost
Go with Lockers for Sure.. You will notice a difference driving in town when cornering, but you get use to it. Just dont power it around as much or the back-end might swing out a little. One thing to check, which no one has said is for rust under the passenger seat and in the corners on the wehere the back passengers pu there feet. Last but not least cargo area near the taligate. Do this because, before you put money in new parts, you might wont to check and make sure your floor pans are good. And if not put the money there to fix them for life. Just my 2 cents
The next time I see someone stuck without a good and easily accessible recovery point on their truck I am going to kick them in the 'nads
and then drive away. Just my rant.
