I'm getting ready to pull the trigger on a SYE kit for my 208 from Tom Wood, along with new F/R driveshafts. I recently upgraded to D60/14BFF and have a conversion U-joint in the rear. Currently running only 35's, with potential future growth no larger than 37's.
My plan was to go with a 1350 CV shaft in the rear, but unsure about up front. What is the factory front U-joint on a K5, and how does it compare to a 1310 (or is it 1310)? My initial plan was to go with 1350 up there too, but according to Tom Wood, a 1350 will max out at 30 degrees and a 1310 will go to 35. 1350 would also require crossmember mods, which is not a big deal, but still a consideration.
So what do you guys think?
Yeah, I have 14" travel up front, but only about 8" is down. That puts my back of the envelope closer to 30 degrees. Still in the danger zone for a CV that binds at 30 though.
