Every now and again my radio cuts out for about 2 seconds and I lose all my presets then it comes back on. Which is anoying and I decided to live with it until now which might be rlated to my fuse problem. I just installed a Sirius car player that plugs into the cigarette lighter and everytime I plug it in I blow a fuse. I don't want to leave it plugged in because I don't want it draining power while the truck is parked. The fuse that keeps blowing is responsible for my cigarette lighter, horn, and the constant power for my radio as in my presetts. The fuse is the standard 20amp fuse. Even though I know it was a bad idea, I put in a 25amp fuse for ****s and giggles and it blew just like the 20amp ones.
Anyone have any ideas why this fuse keeps blowing?
I think i can avoid this by wiring in another hidden cigarette lighter powered by a different ignition on source so I can opporate the Sirius player as I wish and not drain the battery. Then again that would just be side stepping the problem at hand.
I wired the stereo myself into a harness that plugged into the factory one. Now Ive done many of these but I did have more wires from the stereo than on the harness. There was the dimmer one and the illum one that I was thinking I got mixed up and was sending voltage the wrong way for some reason. Was going to cut those loose and see if my problem goes away. Just havent got around to it. Good luck
