Help me!!!!
The beast .... Work very good since 1998 ...
Help me lmc truck , summit racing, pwa inc, etc ,,,, we are near ....
Best regards
hernan
Aca en argentina solo vinieron para la armada las k5 1009 con 6.2 diesel yo consegui una de la embajada de usa en mal estado y la arme pero es v8 305 5.0 es mi 4 hijita todas nenas
saludos
hernan
Says: Here in Argentina we can only find the K5 w/a 6.2 diesel and he found a V8 305 in bad shape in the American Embassy. And he's been putting it together for his 4 daughters.
saludos
hernan
Here in Argentina came to the army only the 1009 with 6.2 diesel k5 I got one of the U.S. Embassy in poor condition and the arm 305 5.0 v8 but my 4 daughter's all girls
regards
Google Translator:D
THEKODIAKGYM- that's a truck that would turn heads here, you gotta have every one looking when you drive that:waytogo:
I don't speak spanish, wish I could help.
That is a very nice K5
If I understand right, you are wanting a stronger rear axle, correct?
The c clip eliminators do not work well under side loading which a 4x4 often encounters.
It would be best to upgrade the entire rear axle to a stronger axle
What makes and models are most common in Argentina ?
He could pull a set of of a 1009 CUCV. Sounds like there are a few floating around down there.
Subscribed-This is just cool and that is a nice looking K5:popcorn:
BLAZINGZUK ITS CORRECT I WANT MORE STRONG AND SURE MY TRUCK , HERE ARE DANA 60 BUT NOT GM 14 ,,,, ITS A PROBLEM:confused:
THANKS FOR ALL FRIEND
K5 OCTANE THANKS FOR THE LINKS AND THE BEAUTIFUL WORDS OF MY TRUCK , I DIY EVERYTHINK IN MY K5 ,,,, ITS A PASION FOR ME AND WE DIE TOGETHER....JAJAJAJAJ
GOOD LUCK !!!!!:waytogo:
si quieres que sea mas fuerte, deves de ponerle un eje de 14 bulones de otro Chevy or GM de 3/4 or una tonelada. Esos ejes tambien son flotantes y no tienes que comprar mas cosas extras
y tambien vas a tener que comprar otros rines con 8 en vez de 6 tuercas
un kit flotante para tu diferencial de 10 bulones no los va hacer mas fuerte solo va hacer a tu billetera mas delgada/flaca
I basically told him if he want to make it stronger he should get a 14 bolt axle from a 3/4 ton or 1 ton truck. It comes with a full floating axle and he wont have to buy any extras beside rims since it goes from 6 lug to 8.
Also a full floater kit for a 10 bolt wont make it stronger only his wallet lighter. Did I get all that correct?
NSXXTREME LA VERDAD ES POR SEGURIDAD NO TANTO POR FORTALEZA NUNCA TUVE NINGUN PROBLEMA Y LA USO POR TODOS LADOS . EL KIT QEU ME PASASTE EL LINK EVITA QUE SI SE ROMPE EL RULEMAN LA RUEDA SE SALGA ? NO LO CONOZCO SI ES ASI EL LO QUE BUSCO Y MUCHO MAS ECONOMICO
GRACIAS POR TU TIEMPO AMIGO :thumb:
60s came in semifloat and full float though, both would be a heck of an upgrade compared to a 10 bolt.
A dana 60 full float, meaning the axleshaft does not rely on the wheel bearings for support will have bolts holding the axleshaft into the housing.
A dana 60 semifloat will look much like you current axle when the tires are off, just bigger
Any Dana 60 would be a great upgrade
Yep as correct as you can get, tell him a Dana 60 would also be a great upgrade will still have to get new rims. I do know of some SF 6 lug 60s in Chile but not sure of make model or how common they are
He's basically asking about the c-clips some more that they might work for what he wants. Which it sounds like he is just concerned with the wheel falling off.
The C-clip will prevent the wheel from falling off if you break an axle but it wont make the axle stronger.
If you have access to Dana 60 that would be a better option to swap under there. You can find a Dana 60 in full floating which is much stronger but you would still have to get 8 lug rims.
El c-clip si va a prevenir que tu rueda no se salga si el eje se rompe pero no previene que tu eje sea mas fuerte.
Si tienes acceso a una Dana 60, ese es una opccion mejor para ti. Si puedes encontrala, una Dana 60 con el flotante difencial va hacer mas fuerte - pero de todas maneras vas a tener que cambiar tus rines con 8 tuercas.
C clip eliminator kits do not like side loading either.
When you are sidehilling on a dune or something the downhill tire has a tremendous side load and c clip eliminators have been known to fail in a situation like that
