it will you will need a flywheel for the 454. Radiator, if in good shape, will work for 454. If you are keeping the tbi you'll need the computer , wiring, and in tank pump. If switching to carb, the block may or may not have a finished boss for a mechanical pump. I would use and electric pump in, or near the tank.
