help on hookinh up tach on HEI
bwoodard
Chicago, IL
Can someone tell me where the green wire from the tach goes on a HEI distributer, Or just tell me where to hook up all the wires.
Thanks Brian
I assume your 'green wire' that you refer to is the 'tach' signal wire for the coil...........right? If so, there is a plug/connection on the HEI that says 'TACH' on the little ear that sticks out for this hookup.
<font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
yes, on the side of the distributor cap, where the wires plug in from the distributor base and wiring harness, there is an empty terminal marked tach on the cap. hook the tach signal wire to that terminal
'95 Chevy Silverado 1500
5.7 V8-NV4500- 3.73 rears
See My Toys: <a target="_blank" href=http://community.webshots.com/user/wdb172454>http://community.webshots.com/user/wdb172454</a>
A .250 Female spade will plug onto this "Tach" connection. Just crimp one onto the end of your wire and press it on. A small mirror might be helpful on the first try.
Michael
<a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
Soory to change the topic a little bit, but what all is involved in the install? I imagine the tach would have a power wire and a sender wire......Where do you hook the power up to?
Where have you guys installed your tachs other than the dash?
<font color=blue> NEVER FORGET, NEVER FORGIVE, NEVER SURRENDER<font color=blue>
Red is 12 V keyed hot
White is power from the instrument lights so the tach will dim with the panel
Black is ground
Green is Tach signal from the distributor
Rene
<font color=green>Dyslexics of the world...UNTIE!</font color=green>
<a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
